Frustrated with Scale Box
cyclone
A customer sent me an EPS file from adobe illustrator. I imported into flexi - got it open okay! Trying to put a contour cut on it but when i go to effects and apply my contour cut it wants to cut on the scaling box. Grrrr I've tried over and over! Any ideas?
gabagoo
make sure it is either ungrouped or unmasked. Make sure it is a vectored file...I have seen many genius designers make vector art from bitmaps...not!!!
GK
my assumption would be that the designer of the original file set the crop marks or trim path already as if the file would be setup for an offset job (very common problem) so flexi is trying to cut the wrong path because of this.
FT1
Are you saying that if you highlight it, it shows a square box around the graphic and it is contour cutting around that?
If that IS the case, take your cleaver/scissors and cut threw the box outline at a corner to cut threw two sides. Then you should be able to highlight the two potions of the box and delete them.
