Full Print or Cut Vinyl Letters
lkt1954
We have 5 large signs (4’ x 10’ horizontally mounted) toletter with sponsors names for a local football booster club. The signs need tobe black with white lettering and we will use poly-metal as the substrate. Wehave a Roland VS 540 so we could do either cut vinyl letters or do a fulllaydown reverse print- keeping the lettering white and printing a blackbackground.
Here is what I see as the pro & cons of each:
Cut Vinyl
Pros--
No ink used
Easier to fix mistakes
Cons—
Wasted material
Having to do shorter runs (5’ or less) to keep contour cutfor varying
More time and labor to align the names
Weeding & masking required
Full Print Mounted
Pros—
Faster- no weeding or masking
No wasted material
No extra time spent on alignment/mounting individual names
Using a laminator to mount the print
Cons—
A mistake means doing the whole print over
Ink cost of printing 50% coverage black on a 4’ x 10’ run ofvinyl
Having to edge tape all 4 sides to ensure no lifting
These signs are going to be facing west into the Texas sunall year long and that could cause cut letters to curl. My initial thoughts areto do a full print, laminate and mount to the substrate.
Would anyone care to share their thoughts and/or advise herein case I am missing something?
Larry
Pro Image
Black substrate and White cut vinyl letters......
Why would you have to use registration marks to cut regular Vinyl......?
kanini
Cut vinyl for this application, gives you good black and you don't have to laminate (use the proper cut vinyl though depending on how long the sign should last). The cost will end up about the same I think if you factor in all material and labour with both methods.
Pat Whatley
One thing to be wary of, in my experience black polymetal in direct sun warps horribly. I replaced two 4x8 signs that looked like somebody had wadded them up.
