Gator Foam.. whats like it?
Discussion in 'Materials' started by ericmitchell29, May 9, 2011.
  1. ericmitchell29
    ericmitchell29 Active Member
    632
    Mar 18, 2008
    Maine
    Hi there, those that have used Gator Foam from Grimco...
    Being that they dont' sell it anymore,
    Can you tell me what is closest to it that they offer?
    Just looking to replace it with what they now currently sell.
    thanks
    Eric
  2. Pat Whatley
    Pat Whatley Major Contributor
    8,592
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Have you called Grimco and asked them if they're carrying a replacement? Not trying to be a smart *** or anything, it's just that Gatorfoam (or UltraBoard or any other brand name) is a pretty unique product in terms of workability.
  3. ericmitchell29
    632
    Mar 18, 2008
    Maine
    yeah I did, they mentioned ultra board as well as insite reveal panel foam core... but the prices are so different that I was wondering which worked better and if anyone could make a recommendation.
    sorry for the run on sentence
    Eric
  4. Pat Whatley
    8,592
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    The Reveal is like a traditional foam core. It's got the clay coated paper faces on it. The Ultra Board is like Gator Foam, it's got the plastic faces. Gator Foam and Ultra Board are apparently so similar I never noticed they'd changed brands. (EDITED TO ADD: READ THE REST OF THIS THREAD. APPARENTLY IT'S NOT THE SAME, AFTER ALL)
  5. ericmitchell29
    632
    Mar 18, 2008
    Maine
    Awesome that answers my question, thanks Pat.
    Eric
  6. insignia
    insignia Very Active Member
    Technically Gatorfoam has a wood veneer face, UltraBoard has a plastic (polystyrene if I'm not mistaken) face. The two are almost identical in what they are good for and their workability, but be aware, they are two different materials.
  7. animenick65
    animenick65 Very Active Member
    1,320
    May 18, 2005
    Boston, MA
    Gator and Ultra are extremely similar. You should be able to transition without any issues.
  8. marcsitkin
    marcsitkin Member
    168
    1
    Test it first. We have used gatorboard for 25 years, had some ultraboard delivered ("it's the same") and the mounting failed to adhere.
  9. Pat Whatley
    8,592
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    That's dang interesting (and correct). I've only been using Gatorfoam since Weasel Booger posted pics of a project he did with it and all they've ever sent me was stuff with a plastic face. I never knew they were apparently sending me the wrong stuff the whole time.
  10. weaselboogie
    weaselboogie Very Active Member
    3,835
    9
    38
    Apr 23, 2006
    Us
    I worked with gatorfoam for two years before I read that its a wood composite. The entire time I thought it was a plastic type of face too... I've never seen a veneer like that and it's got to be at least a 98% white.
  11. boxerbay
    boxerbay Active Member
    938
    71
    28
    Nov 25, 2010
    Darkside of the Moon
    Call United Industries - 479-273-2924
    http://ultraboard.com/
    Explain to them you are a sign shop and you need POS samples of their materials in order to sell more of their products and educate your clients as to their many option of UNITED products. They will send you a FOAM CORE PANEL kit. It has samples of all their media in 8.5x11
    They have:
    Ultra Board - similiar to what people call gator board - plastic face
    Ultra Mount - paper faced poly coated - semi rigid
    Ultra Core - paper faced clay coated - softer - more spongy
    Ultra Plus - very rigid and has a thick pvc face - heavy duty
    Ultra Aluminum - foam board with aluminum face
    Ultra White DP - similiar to ultra mount - but this is for DP direct print - coated for flatbed use.
    We use ultramount and ultraboard. ultracore is a bit spongy and tends to bend on larger 24x36 pieces. if the job is a small 8.5x11 pieces then you could get away with ultracore and save some money if it is a large qty job with small pieces.
    hope that's helpful clearing up the differences. I just had to go over it with all the sales staff here. I still get order requests from them with "mount to gatorboard" when they really mean ultraboard.
    for sure get a kit, put it on the front counter and clients can choose the board they like.
