GBC Eagle 65 laminator service
curry.copy
Is there anyone in the southern california area who services GBC laminators?
Our GBC Eagle 65 for some reason will not turn on and I have been through everything I can think of.
In Laminator's cases you need to contact manufacture or who you bought it from.
For the most part you can usually get a tech. on phone explain problem and they will send you parts if needed.
I would fix it yourself just b/c of price of your hardware compared to the cost of a technician to come out isnt going to be cheap.
GBC tech should walk you through it on the phone
gnemmas
Our Royal Sovereign speed up/down button not working, we took it apart, adjust the position and fixed it.
Could yours be just the on/off switch burned off? See if you can bypass the switch.
