GCC Expert II-52 LX cutting issue please help.
Discussion in 'Miscellaneous Print & Cut Systems' started by Kemraj, Jan 31, 2020.
  1. Kemraj
    Kemraj New Member
    17
    Aug 27, 2019
    Trinidad
    Good day guys, I'm have a big issue.
    Im using Flexi the software for the Plotter, When i'm sending Contour jobs under 48x 30 Inches its works fine.
    And anytime i'm sending larger files its just sends and the error light on the plotter starts to blink.
    If i cancel the job when its around 20-30% sending to plot it works but only cuts the 20% that is sent.
    Please tell me whats going on here. How can i contour cut larger jobs. Or is this a limitation of the plotter.
  2. Head print
    Head print New Member
    1
    Feb 21, 2017
    East Tennessee
    Did you resolve this issue? I mistakenly purchased a Titan 3 64" cutter and always had the same issues as you stated. Turned out the Titan cutter with Flexi had the same work envelope as you described. Was curious if other cutters behaved similarly with Flexi. Seems like the GCC cutter has same problems? Loved my Expert 2 24" and hated the Titan on all levels. You get what you pay for i guess
