Gemini Letters Re-Paint question....
artsnletters
I just got some cast aluminum Gemini letters for a client to match some existing ones....and the color is not too close.My fault. Instead of shipping them back i want to simply re-paint them. Do any of you out there think that a spray-bomb like Rustoleum or Krylon (a name brand) will last? Or should i use a single stage automotive urethane & use my gun? I figure it needs to be good for at least 7-10 years although the existing letters MAY need a repaint in the future.
Tim
PS i don't have access to Matthews paint system just a auto paint jobber down the st.
G-Artist
Gemini folks are usually great to deal with.
Contact them and I am sure they will tell you the very best way to
deal with the issue so you get it right the first try.
petrosgraphics
be on the safe side, send them back to gemini, good people, easy to talk to......
spray cans would be the worst thing you could do......
Letterbox Mike
Preferably sandblast them to the bare metal, prime with an automotive etching primer, then a filler primer, sand the faces between primer coats with 400 grit, spray a few coats of single-stage automotive and a few coats of auto clear. Will hold up great.
If you can avoid it, don't use rattle cans, but If you must spray bomb them, I'd recommend going to an auto parts store like Pep boys or Auto Zone and getting their automotive sprays like DupliColor. I've got DupliuColor painted things that have been outside for 5-7 years and still look pretty good. Make sure you use their clear coat.
