Gerber Edge 2 CMYK Issues
Russ9114
I have been trying to print to my Gerber my using process color CMYK. The color is perfect but i keep getting these little multi-color dots all over my print. Any ideas why it would do that?
J Hill Designs
process colors are made with multi-colored dots - is it happening in the white spaces or something? if so its a profile issue - if not, then the little dots are what make the color
signage
post a picture of what is happening.
Also what software are you using to run edge? and version.
Russ9114
This is what it is doing
Russ9114
Usually that is what i would do. But my store i work at is getting rid of all my vinyls but CMYK. So i been trying to do my orders with just CMYK but this is the result
signage
try these setting from Fred!
Vector Fills
Classical Dot Halftone
LPI = 53 for gradients
LPI = 70.7 for most solids
LPI = 90 for solids in mid to lighter shades
Raster Fills
Gerbertone STC Photo Halftone
Output Color Profile
Turn off automatic color management in GSPPlot and manually select the color profile named Gerber EDGE II 300 DPI CMYK.
and read this thread
Fred Weiss
You probably just need to change the LPI of the dot pattern. If you are printing from a vector, use Classic Dot and set the LPI for 70.7. If you are using an image, use Gerber Tone STC Photo and set the LPI for 70.7.
If that doesn't work, try changing your output DPI to 300 x 300 (if you're printing at 600 or vice versa if you're printing at 300.
If all else fails, in GSPPlot, turn off your automatic color management and manually select the Gerber Edge 2 CMYK 300 DPI color profile from the drop down menu and which is a great all around profile.
