Gerber Edge FX vs Summa DC5sx
Discussion in 'Miscellaneous Print & Cut Systems' started by phatmanu812, Apr 28, 2015.
  1. phatmanu812
    phatmanu812 New Member
    21
    Sep 13, 2011
    Texas
    Can anyone compare and contrast the two digital printing systems mentioned?
    I have an Edge FX and am considering the Summa DC5sx.
    Specifically interested in:
    1. printing white on clear
    2. printing on Convex chrome
    3. cutting accuracy
    4. foil cost
    5. anything else you may think is relevant
    Only first hand experience please.
  2. SellersSign&Design
    SellersSign&Design Active Member
    718
    35
    28
    Apr 22, 2013
    Harrisburg, NC
    I did a lot of research on the Summa printers. I currently run an Edge LE which I love, it just doesn't print wide enough for everything I do. There were two main drawbacks that kept me from buying a Summa, or at least buying a new one. The first is banding in the prints. All the samples I received that were printed with spot colors in an area big enough to require more than one pass had noticeable banding between the passes. The second problem was head replacement prices- after the warranty is up the head is just as expense to replace as a Gerber printhead, and I during my research I found many cases where they fail more often. There were some other more minor issues such as contour cutting, Summa doesn't recommend removing the material from the printer, laminating and then reloading to contour cut. They say you must use a stand alone cutter. With all that being said, I will most likely still buy one eventually due to it being the only real solution if you need thermal printing capabilities at widths wider than 11.88 inches. I'm just holding out for a deal on a used one.
  3. artofacks1
    artofacks1 Member
    436
    6
    18
    Mar 15, 2014
    Los Angeles
    I like my Edge fx printer but I will admit the banding issue is scary. The edge fx does have a lot of miss prints to though. You get missed lines or dots the the foil doesn't print on. I as of late print everything 600dpi and that has helped. I too wish the print width was bigger. I am worried about having to buy big wide material though. The size of the printer and the space it takes up.
    I tried getting samples on convex from summa but never did they come through. The difference between me buying a edge fx or summa dc5x was literally customer service Cus at the time I was blind and didnt even know which would be better.
  4. artofacks1
    artofacks1 Member
    436
    6
    18
    Mar 15, 2014
    Los Angeles
    If latex ever gets white and mirror chrome prints. Man oh man its a game changer.
  5. SellersSign&Design
    718
    35
    28
    Apr 22, 2013
    Harrisburg, NC
    The Edge printers are tanks. Like you say, they can be quirky from time to time but all in all they just work. That is the biggest issue for me, I would expect the same reliability and quality from a summa and I don't know that it would live up to those expectations. I just wish Gerber would come out with a 30" machine that works as good as the Edge.
  6. artofacks1
    artofacks1 Member
    436
    6
    18
    Mar 15, 2014
    Los Angeles
    Even a 24" would help
  7. signage
    signage Major Contributor
    9,416
    57
    48
    Oct 5, 2005
    Penn
    They did, it was called the Maxx!
  8. artofacks1
    artofacks1 Member
    436
    6
    18
    Mar 15, 2014
    Los Angeles
    Is it still around?
  9. SellersSign&Design
    718
    35
    28
    Apr 22, 2013
    Harrisburg, NC
    Yeah but I said a 30" machine that worked as good as the Edge! From what I've heard the Maxx was a disaster haha
