Gerber Edge II help!
Discussion in 'Gerber' started by gnemmas, May 10, 2007.
  1. gnemmas
    gnemmas Active Member
    856
    20
    18
    Nov 7, 2006
    CA
    The foil advancing button not responding. Was printing all day yesterday, at the end when it happened. The machine initials OK. Just the foil button dead. Called tech support, can only leave message. Figured I may get support here faster. Thanks in advance.
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,533
    401
    83
    Sep 11, 2003
    Olympia, WA
    You can isolate the problem a bit by trying to print about an inch of width to see if the motor is advancing the foil during printing. If it does then you're probably looking at the control panel module being bad. If that is the case, then you can switch it out for another one without a trip to the factory.
  3. gnemmas
    856
    20
    18
    Nov 7, 2006
    CA
    I try your suggestion, printed 3" strips. The foil is not advancing. When I lift up the cover, the foil is loose, only advanced by the vinyl movement.
  4. gnemmas
    856
    20
    18
    Nov 7, 2006
    CA
    OK, one tech support determined that the motor is out. Need to order from Gerber. Any one has a spare motor?
  5. canadianchef
    canadianchef Member
    110
    Jan 15, 2006
