To admin: Please relocate thread if this isn't the proper place to post. THX
I just recently acquired a Gerber Edge & a GS-15 plotter on a deal I couldn't turn down. The printer has a bad head. 2 inches of the vinyl has several pixels burnt out. But I can work around it.
I have the PC tower & dongle that came with the system. However, the computer will not power up so I can't access the software. I've been wanting this type of print system because of being able to print white onto film something other printers can't do.
So I am trying to find software that would run this printer & plotter. I don't need to have the latest software which can get pretty pricey. I just need something that could get me up and running with reasonable costs something that I can run on Vista.
I would also need to locate the cable to the printer to PC connection which is missing.
I also bought the plotter GS-15 with the printer and that cable has the dongle Graphix Advantage hooked up to it, that is where I am told the software runs from.
Anyone with experience with these machine that is willing to help me out would be highly appreciated.
The plotter had a continuous beeping sound till I press reset, but I'm not sure if that's because it's not connected to the computer software, so I keep it off. I did hit the skew buttons and nothing happened, so I don't know if the plotter is damaged or it just won't function without it recognizing the software.
If I can't get the plotter working for some reason I will try and cut my designs off of the Roland. (yes, I know it's pin fed & & uses a different system But I found a guy that does it this way because his Edge does't have the plotter.)
Well, again thanks to anyone who is willing to help me out with this issue.
