Gerber fx
Welder.man
Today I found a complete Gerber fx set up I offered the owner the my maximum budget of $12k and he seems interested he had $16k on it. He told me it is three years old and it has not been used for 12 months.
Any comments on this set up. Please any advice
Fred Weiss
I took his post to be in Oz dollars so some translation is needed. In U.S dollars, I have seen recent offers similar to that but with an FX much newer for around $8K to 9K USD for a used FX.
The Equipment Guy
When buying a used edge of any model, ask them to print you 2 11.75 inch high squares, use cobalt blue, print the first one with a 50% half tone and the second a linear fade from 90% to 0%. Tell them to clean the printhead first and use good quality clean 2 mil vinyl.
What you are looking for is a burnt pixel (quite obvious, its a thin white line that does not print) or in the fade a dark section that interrupts a smooth fade, this indicates a bad clutch.
I don't know about your country, but it looks a touch expensive. I do like the FX, but it would be cool if you found one bundled with an enVision plotter, they are a bit faster and make some really cool musical sounds for you, lol!
I always have used Edges on my website, no FX's currently though.
Craig
Welder.man
Thanks for the feedback. I went and bought the set up for $12k Australian.
it should be here in a week or so.
Now all I have to do is learn how to use it all.
Tony Teveris
Make sure you register the software. If your buying it from a per registered user I believe there is a "transfer registeration" form on our WEB site.
Welder.man
Thanks tony I will be sure to do that.
I have been looking to buy a new computer as well and was wondering if the Gerber edge fx will run on windows 7, the computer sales man suggested getting windows 7 professional as he said it has 7 and a version of xp that is handy to run older software.
Can anyone tell me just what i should be looking for in a computer system, I will be running the edge fx,a Roland GX24, a epson R2880 and the software I use is corel X4, Vinyl master pro V2.95 vista edition,
The Equipment Guy
The Edge is a no brainer, the issue you might have is that some computers do not have the serial port for the EnVision plotter.
To transfer registration...
http://www.gspinc.com/downloads/PDF/fastfacts/1006.pdf
Windows compatibility (does not include Win 7 as of yet)
http://www.gspinc.com/downloads/PDF/fastfacts/1142.pdf
Lots of other good stuff in GSP's fastfacts site...
http://www.gspinc.com/default.asp?contentID=203#EDGE
I highly recommend spending the time in the tutorial manual, its well written. then look up the fast fact on 5 easy steps to Edge printing.
Lastly for beginners once you know the things that usually stump you, you can use the "Select" drop down menu in Omega to troubleshoot. For example, you know that you are printing on only white vinyl, so when you cant figure out why it looks wrong, you go through the various selection menus and you see you can select more than one colour of vinyl, then you know your issue is that you have multiple vinyls assigned in a print job. This works for open shapes, unwanted strokes, having unwanted process work in a spot job, having cuts on or off on the wrong shapes and many other common errors.
Good luck and enjoy! They are a really fun machine to operate.
Craig
Malkin
What you are looking for is... ...in the fade a dark section that interrupts a smooth fade, this indicates a bad clutch.
Our older Edge has this issue. Is this usually an expensive fix? We don't print as much with it as we used to because of the new solvent machine, but I would like to fix this someday.
