Need Help Gerber GS15plus - not cutting file sent
The cut job does not cut - what would cause this. (See video)
  • GS15
    Votes: 0 0.0%
  • GS15
    Votes: 0 0.0%
  • Total voters
Jburns
It would help if you tell us the software you are using, and are you using the grey factory cable? it has three or four pins I believe for the back of the plotter.
Titch Sanders
Yep, this does sound like a problem with the signal from the pc...if you have another cable..may well be worth trying that....
cutdate.com
Monument Lettering Sandblasting Granite Signs
Are you using a usb to serial adapter? If so that would be the first thing I would check.
