Need Help Gerber Sabre 408 Spindle Motor Issue
Discussion in 'CNC Routing & Laser Cutting' started by David Donaldson, Mar 20, 2019.
  1. David Donaldson
    David Donaldson New Member
    6
    1
    3
    Mar 13, 2019
    Northern Ireland
    We have a sabre 408 with spindle motor. The spindle motor is not turning on, either when a job is sent or when selecting motor warm up.
    When I open the motor control cabinet the inverter display says CALL, when I select motor warmup on the keypad the display on the inverter changes to 333.3 I would therefore assume that the inverter is getting a signal from the electrical cabinet – the spindle motor does not operate but the dust extractor does.
    However when I switch the inverter to “local” control and hit run – the spindle motor does indeed run
    Could anyone advise what the issue may be?
  2. chadorama
    chadorama Owner & Sole Employee
    10
    7
    3
    Dec 20, 2018
    Denver, Colorado
    What happens when you send a job? Do you get the spindle error beep or does it think that the spindle is running and try to cut? Sounds like you might have a problem inside the main control box, not the spindle controller.
  3. Mike
    Mike Member
    30
    Apr 18, 2003
    Michigan
    Is the serial cable plugged in to the back of the cabinet
  4. StarSign
    StarSign Active Member
    589
    61
    28
    Sep 20, 2011
    Southern Utah
    Have you tried hitting the emergency stop and then resetting the machine? Sounds crazy but this has worked in the past when we get an error we can't figure out.
  5. David Donaldson
    6
    1
    3
    Mar 13, 2019
    Northern Ireland
    When I send a job the router behaves exactly as if the spindle is running - no errors.
    In fact once I start the job the display changes on the inverter and if someone hits the local/remote button on the inverter and the hits run the spindle will run and the job will complete as normal - except that the spindle keeps running after the job ends
  6. David Donaldson
    6
    1
    3
    Mar 13, 2019
    Northern Ireland
    Hi Mike - yes the lead is connected - I have disconnected it at both ends and reconnected it .
  7. David Donaldson
    6
    1
    3
    Mar 13, 2019
    Northern Ireland
    StarSign - yes I've hit the emergency stop but unfortunately it did not cure the issue .... I've went on to "hit" every other part too, but that's from pure frustration rather than technical prowess o_Oo_O
    • Like Like x 1
  8. chadorama
    10
    7
    3
    Dec 20, 2018
    Denver, Colorado
    Your problem is not in the spindle cabinet, it's in the black control box for the machine. Seems to me the signal between the spindle controller and motor is just fine but the control box is not telling the spindle controller when to turn on and off. The control cabinet is still recognizing the spindle as functioning. It's a bad card or connection in the big black box or the connection between black box and spindle box. When you turn on the black box, does it give you the same "beep... beep... bee-da-beep" as usual or is it different? Take the lid off of the black box and look at the led's. green led is good, red typically shows a malfunction. I have the full blown service manual if you need it.
    • Like Like x 1
  9. David Donaldson
    6
    1
    3
    Mar 13, 2019
    Northern Ireland
    Thanks Chadorama - All is locked up here for the night now, but I'll check out the LED's and the beeps in the morning - to be honest I never noticed if the beeps were different or not. I'll could meter the serial lead but don't have a diagram for it - do you know if its just straight thru wiring? I'll update on LED's and beeps tomorrow :). Thanks again
  10. David Donaldson
    6
    1
    3
    Mar 13, 2019
    Northern Ireland
    So I've just checked out the LED's +24V, +15V, -15V and +5v are all lit green. The green LED's for SPIN#1 and SPIN#2 do not light at all. The two red ones (Amp Fault and Emgcy Sw Fault) are both off although the Red Amp Fault one lights for a second or two during start up. Start up beeping was different when I tried a few startups but seems mostly to be Beeeeeep ... beeep...beeep..........beep.beep.beep. Not sure what any of this means :)
