SignworksUnlimited
We have a Gerber Sabre 408 router that has started to produce rough edges on routed pvc. We are using Enroute4. We have also noticed that the gantry is loose and we can move it by hand about a 1/16" in both directions when the table is idle. Has anyone had issues with "chatter" in the gantry causing quality issues on harder substrates? I should add that we do not see the problem with softer materials, such as HDU.
We replaced the bearing bushings and that helped a little but think it may have more to do with the connection to the lead screw under the table. Any help or recommends will be appreciated!
Thanks!
Thanks!
