Need Help Getting some Banding
BANDING
  • Need some advice
    Votes: 0 0.0%
  • Thanks in advance
    Votes: 0 0.0%
  • Total voters
Jim Hill
I would try all of the simple fixes first!
Such as replacing the cap tops with Roland OEM Cap Tops.
Making sure all the dampers are working and that they do not have any air leak like around the little rubber O ring on the tube going into the dampers.
The problems with the Roland Printers is there are so many places where an air leak can be it's a task checking each and everyone from the manifold all the way to the drain tank and everything in between including the tubing, ink pump, The Y fitting, cap tops and tubing and the two small springs under the cap tops, capping station must be working properly.
I air leak can take hours of either your time or you can pay a Roland Tech to come and find it for you.
Jim
