UFB Fabrication
How so?
His location is very wet and damp, very tropical. LED's would die with the extreme climate and moisture, fluorescent lamps are affected on the amount of starts and you would have to replace the whole cabinet every 18 months to 2 years. Do a good 15/13mm Tri-phosphor white grids, load them up properly and you'll never have to worry about service for a decent score at a minimum depending on how good the processing was.
You are looking at a industry proven 15-20 year lamp life
X2
I would mount the trans remote because that will likely be the part that is likely to fail. The neon (done properly) will be working when the guy has moved or gone out of business. If its 3 feet of the ground I would do flex face as a big seam from a pan face wont look great up close.
