Glass printing problem
arvindrlaxman
We had printed picture with white ink on an extra clear glass ! We had used a coating for the same. after letting it cure for 12 hours. A strong layer of the print just detached itself and we were able to remove the print in one go. Need suggestions. facing a hard time !
RyanFelty
I know with our flatbed the inks...especially white do not adhere to glass well at all. Do you use any sort of adhesion promoter?
arvindrlaxman
We do use adhesion promoters ! Company says white needs 12 hours curing ! Still, it has not been adhered properly... There's no proper solution for the printing yet.. Some days it gets adhered properly...some days it doesn't...
RyanFelty
Gotcha...the only other thing I could think of would be to turn up your lamp power? I had to do this to compensate for my lamps starting to wear out. Good luck I hope you get it figured out!
SignMeUpGraphics
Super Active Member
Find someone who can turn 3M Primer 94 into an aerosol for you... spray that onto the glass and let dry for 30 minutes.
Works quite well for Océ adhesion onto glass.
