Go ahead, tear it apart.
Discussion in 'Logo Design' started by FTG, Jun 1, 2012.
  1. FTG
    FTG Member
    91
    2
    8
    Aug 17, 2011
    South Dakota
    Logo for a Butcher Shop/Liquor store. Odd combination.
  2. eahicks
    eahicks Very Active Member
    1,984
    246
    63
    Apr 17, 2012
    DALLAS, TEXAS
    I like it...but the name is confusing. Is it a butcher or a liquor store?
    Edit: nvm...I just read your full post.
  3. FTG
    FTG Member
    91
    2
    8
    Aug 17, 2011
    South Dakota
    It is quite confusing, the owners have been struggling with the name for some time. It was originally a butcher shop (Dakota Butcher) then they expanded to a liquor store.
  4. Border
    Border Very Active Member
    2,657
    3
    38
    Feb 8, 2007
    Minnesota
    Liquor in the front, Angus in the back???
  5. GRAFIKWORX
    GRAFIKWORX Member
    41
    Looks Great for the Butcher shop.
    needs help to get the Liquor:bushmill: Store message across.
    the wording needs changing somehow..
  6. signage
    signage Major Contributor
    9,207
    25
    48
    Oct 5, 2005
    Penn
    :help I thought it was: Liquor in the front, Poker in the rear:omg::ROFLMAO:
  7. bob
    bob Major Contributor
    5,189
    283
    83
    Nov 4, 2005
    earth
    Hard to read and the ersatz chrome plated bovine isn't doing much for it. I kind of like the cow, I'm not all that fond of the treatment in its white areas. Also, its eye makes it look like it might be the cow from hell.
    All that and then consider...
    Getting rid of all of the gradients, all of them, they contribute little if anything.
    Choosing different type faces for 'Dakota' and 'Wine & Spirits'. The latter reads as a mis-spelled 'Wine U Spurious' at first glance. Even if it read properly this is not a particularly pleasant face. Unless third rate graffiti is what you're trying for.
    Move 'Dakota' off the top of 'Butcher'. It looks like three suits in a two suit bag the way it is.
    I assume that's some sort of wood grain you're trying for. If it is make it coarser so that it's clear what it is. Right now it looks like the output of a printer in the process of running out of ink. If it's not supposed to be wood grain, do something else.
    If you must have a drop shadow, try it just on the copy on the shield and not on the white surround. If it should lapse over on the white surround, erase it there so that it appears that the copy is stood off the shield and not the entire thing stood off from the rest of the universe. For there to be a believable shadow there must exist something upon which to cast that shadow.
    Since you asked...try it again.
  8. Coloradosigns
    Coloradosigns Major Contributor
    7,929
    54
    48
    Sep 10, 2010
    Denver.
    not bad. try doing it flat without gradients.
  9. BIG EASY DOES IT
    BIG EASY DOES IT Very Active Member
    2,021
    72
    48
    Mar 14, 2011
    CA
    Is there some way you could put the bulls hand coming out of the top of the sign holding a brew. That might help.
  10. TammieH
    TammieH Very Active Member
    1,011
    46
    48
    Nov 28, 2011
    Pacific NW
    I like it!
    Or make the bull urinating into a bottle?
    LOL I had to! ;-p
    Honestly, I like the sign the way it is. But I am easy.
  11. visual800
    visual800 Very Active Member
    3,631
    177
    63
    Aug 4, 2010
    montgomery, alabama
    I love everything except I cannot stand that dakota font
  12. Jillbeans
    Jillbeans Major Contributor
    14,457
    16
    38
    Dec 24, 2003
    Butler, PA
    I really dislike the gradients for one.
    The ring needs to be gold.
    Not in love with the Dakota font either.
    What about adding another panel underneath that said WINE • SPIRITS
    Then you could put an ampersand after BUTCHER
    When shading a script I have always been taught to go down and to the right, it may help it a bit. But I'd consider using a nicer script.
    Love....Jill
  13. Marlene
    Marlene Major Contributor
    10,966
    262
    83
    Jun 8, 2004
    Vermont
    agree with that. the bull looks the the layouts looks more sports related than a place to go some meat and booze. the best they can do with a combo like that is to make them separate and not try to combine them. make the butcher part clearly a butcher shop and then add the spirits part as a separate look of it's own as if there were two tenants sharing the same space. any attempt to combine the two just will look odd.
  14. SignProPlus-Chip
    SignProPlus-Chip Active Member
    603
    Feb 19, 2012
    Bluffton, SC
    I think a big confusion point is that having "Dakota Butcher" in two different fonts makes it look like "Dakota" is the name and "Butcher" is strictly what they do.
    I would lay out "DAKOTA BUTCHER" on one line using the current font for "butcher"
    Then below that, enlarge "& Wine & Spirits" so it's more prominent.
    Or talk them into changing the name to "The Drunken Butcher" ;)
  15. Pat Whatley
    Pat Whatley Major Contributor
    8,562
    77
    48
    Sep 29, 2003
    Wetumpka, AL
    WHOA! Mark that on your calender. Bob likes something. This is a great day in Signs 101 history!
