Good RIP computer?
sinclairgraphics1
Sinclair Graphics & Installations
I'm going to upgrade my dinosaur HP desktop I use for my rip for a newer one and just thought I'd get opinions on a good machine for ripping? I'm using Flexi Photo Print 10 for my rip. Also going to be running CS5 on it. I was looking at a refurbished HP Pavilion HPE H8-1100Z Desktop, Six-Core 3.9GHz with 6gb RAM that is selling for a great price. What do you use or recommend?
SignBurst PCs
I would humbly recommend one of our SignBurst systems. We are a Merchant Member here on Signs101 and we work with SAi (Flexi) quite a bit. As a matter of fact, we travel to many of the tradeshows with SAi and demo Flexi and and Photo Print on our computers.
I would say a Blaze or Inferno, depending on how much you actually work with CS5.
We have some specials running right now. Please feel free to give me a call anytime with questions.
Matt-Tastic
I'd also recommend the Infinity line of computer from Advantage Sign Supply. I've seen them in several sign shops and they are very snappy to work with.
mgcustomgraphics
Im also very interested in upgrading, not quite sure what i really need, but this is my problem, i also have flexi 10 for my cutter and when i run a big file, the computer will just freeze or take very long time and cant afford to work like this anymore
SignBurst PCs
MG, email me or give me a call anytime. I would be more than happy to talk to you about what you have going on and what we can do to help. We work with the Flexi crew all of the time and as a matter of fact, SAi uses our SignBurst computers at their facility and at tradeshows around the country.
choucove
I've had the chance to meet and talk with Casey before and I can tell you he really does know his computer systems well, and they are great machines for design work.
To output to a single printer, most mid-range desktops today would offer the capabilities of doing this for you without much difficulty. However, there are very specific components and combinations that can make a system more than just "capable" of the job and actually handle it with incredible speed and efficiency. Depending upon how much designing you are intending to do on the computer (and the level of responsiveness and demand you are placing on it in Adobe) then you may be needing some more performance benefits in other areas as well.
For design work and output to a printer/plotter, there is very little GPU intensive work that is done. In fact besides helping to speed up some renders in Photoshop, the only benefit from more powerful graphics cards that you may get would be smoother scrolling while in massive art files, higher resolutions, or in the case of professional desktop graphics cards, better color fidelity. Instead, the majority of your computation is going to be placed on three things in this order: Processor, Memory, and Hard Drive.
Get a decent processor, at least a quad core, preferably with hyperthreading, like an Intel Core i7 series (Ivy Bridge or Sandy Bridge-E) to leverage the maximum multitasking capabilities when your computer really needs to crunch some numbers. Going with an Ivy Bridge platform computer is going to be cheaper overall, but if you want the absolute greatest performance and want to support a huge amount of RAM, then step up to the LGA2011 Sandy Bridge-E platform.
Memory is cheap right now, so go ahead and load up on as much as you can afford. Most desktop users are never going to really need more than 4 GB for daily usage, but when you're designing and outputting large graphics files, the more RAM you can throw at it the better, especially in programs like Adobe that can utilize all that extra memory. There is a delicate balance between high speed memory (for example, DDR3 1600 Mhz) and low timings (for example, CAS 8-8-8-24). This is getting pretty detailed, but if you are having a custom system built this may be something you want to have specified or clarified for you is the memory type, speed, and timings. You will get higher throughput and thus greater performance from a system with higher speed and lower timings! If the system is an Ivy Bridge platform, this has a dual-channel memory controller which means for the best performance you should use pairs of memory sticks. Likewise, the Sandy Bridge-E platform is a quad-channel memory controller so the best performance is going to be in groups of four memory sticks.
Hard drive recommendations are going to vary greatly depending upon how you use your computer and the rest of your computer network. For example, are you saving artwork files directly to the computer or do you have some form of network shared storage? Ideally, storage of files should be moved off the local machines onto a redundant shared storage device, meaning all your RIP and design computer has to do is RIP and design, not file sharing and backup as well, and you don't have to worry about losing files if your computer goes down. If you don't have to save a bunch of files to your local computer, then you don't need a massive hard drive really. I'd recommend looking into solid state drives, one for your operating system and programs, and a whole separate one for use as a scratch/temp disk on Adobe and Flexi. The primary storage subsystem - traditionally mechanical hard drives - is actually the slowest part of your computer system when it comes to throughput and accessing and saving files. The faster you can make this, the faster the entire computer operates. This is the benefit of SSDs as they are many times faster than your traditional hard drive. Be careful, though, as they come in smaller capacities than standard hard drives. I've seen people making the transition to SSDs for the first time purchase too small of drives and end up having to upgrade again very quickly because they were running out of space. I'd recommend no less than 120 GB SSDs for each the operating system drive and for the scratch disk drive. Preferably a 250 GB SSD or better for each! And not all SSDs are created equal as well, there are some which have had a proven history of issues or performance problems where others have built a reputation of reliability and speed!
GP
For our RIP, we have a 5 year old mid range HP Pavilion desktop. All it does is run Caldera and it works just fine.
SignBurst PCs
All good points Brett.
I speak with every customer and walk them through what they actually plan to do with the computer that they are buying and make recommendationS based on that. Everyone has a little different situation and we build the system and make an overall plan based on what the customer needs. Not everyone needs the same thing.
That is where SignBurst is different than the others out there. You are not just getting a computer, but a solution. We never charge for basic support and can offer all kinds of recommendations. More often than not, I find myself logged into a new customer's computer assisting with things that have almost nothing to do with the new computer. We want to make sure that our customers are taken care of and they enjoy their new computer. We are happy to go above and beyond and our customers seem to appreciate it.
nate
Yea--
Make the switch to Caldera... No need for amazing machines as you're never waiting on the RIP!
