graffiti lam
signwizz
i just outsourced a large print with graffiti proof lam if i write on it with a permanate marker what do you use to get it off want to test a off cut peice to make sure they put it on seems awfully thin
thanx shane
ProColorGraphics
I know I have used Hexis material and they have a special gel for removing the graffiti or marker. I don't know what else you would use. Maybe acetone or something like that.
Vandal Guard USA
Lacquer thinner will do the trick everytime. If any of you are in need of high quality Anti-Graffiti laminate that won't break the bank check out Vandal Guard anti-graffiti laminate. Graffiti such as paint and permanent marker wipe away easily from Vandal Guard using laquer thinner and a rag. It's a specially formulated polyester laminate that is dimensionally stable and can be applied over cast or calendared vinyl. 54" x 100' $249 & 36" x 100' $179.
WYLDGFI
we actually use a clear Polyester overlam for anti grafitti. works great even against sharpies.....
