Need Help Graphics on abs
Stevealex
Hello, i have a customer that needs graphics on sheets of ABS (Acrylonitrile Butadiene Styrene). The problem is that its a textured material. He had a quote for someone to print on them with a flatbed printer but it was $40 a sheet. Does anyone have any suggestions? Its black now but needs to be white and have a logo overlaid which should be monochromatic. Would painting it white then using spray mask to shoot the graphic work? Seems like it would be impossible on account of the texture. Anything would help. Thanks.
2B
So what is your question?
textured material is easy to do, just use the correct material, cast so it conforms to the texture, if you don't have a flatbed.
are you wanting it lower than $40 per sheet? if so then use a lower grade material and see if it sticks to the material
Stevealex
Ya ive just had problems even with cast when applying to textured substrates. Im afraid it will peel. The texture is very small variations. Lots of little nooks and crannies to get into. Wondering if its something anyone has tried.
2B
I'd be more concerned about the surface energy than the textured surface. You may need to look into a high tac material
To over come the texture, do a post heat and use an application roller wheel
Sent from my SAMSUNG using Tapatalk
Oroscoe
Ritrama has vinyl with with an adhesive for low surface energy substrates. 99X or X99 adhesive (can't remember exactly). Absolutely awesome.
Christian @ 2CT Media
I see you are in Mesa. Is this something you are able to do?
Yes we can certainly print it for you or if you want to attempt application you can borrow our flatbed application table.
Shoot me a PM you can swing by anytime. We are actually pretty much in QC right on Pecos and Sossaman.
