labor in what sense of the word?
What is required when cutting several side by posters. What is the process and how much effort is needed? Is it a one man job when cutting 150' roll at a time? Just some insight.
Ounce you load the plotter, you walk away, so then it becomes a NO-MAN job, the plotter cuts the material and it outputs into the basket. As long as you set up the material correctly and the plotter is tracking correctly, it should be able to run un-attended.
never heard of plotting out a poster
How much labor is needed when using the Graphtec 54” Plotter w/ stand and basket?
And my answer to the original question would be, the same amount of labor needed to run a 30" Summa plotter.
There is a Summa plotter?
As in Sumo Wrestler? I like the sound of that better already!
