Graphtec 5500 not completing job...
Circleville Signs
Here's the scoop. I've got to cut the side reflective stripes for a Sprinter ambulance. I've ruined 35 ft of expensive material already....ARGH!
Each side is just over 17' long. I send the job, and it cut roughly 13' of it, and then stops, says job is done, and gets ready for the next job.
WHY IS THIS HAPPENING!!!! (been that kind of day...)
Ken
What software are you using to send to the plotter?
Check your design for hidden cut lines etc.
Also check media size settings.
Ken
Circleville Signs
I use Cutting Master Pro to cut straight from Illy. No hidden cut lines in the design. Media settings are 15"x1980" (roll settings).
I just know that this thing is killing me and while it's at it, costing me a good chunk of change! Now, I AM scaling the job, because Illy doesn't have a 17' working area. I just did the stripe layout at 1/20 scale, and scaled it up 2000% in Cutting Master. It's showing fine in the preview...
Circleville Signs
Yup. It's killing me. And because it's reflective I can't just lay a big 9" stripe and then go back and accurately cut out the door handles and rubber stops.....
Circleville Signs
Actually, taking out the blade makes 100% sense. I'm so frazzled I didn't even think about it. I've been here 60 hours already this week, and no end in sight....Ugh.
ironchef
Hey. Any luck? I had same problem with fc8000-75. I never fixed it. Just cut the job on our old mimaki cg130fx. I was shocked that a new graphtec couldn't keep up with an old mimaki cg.
