Graphtec 7000 Max Cutting Length too Small
animenick65
For some reason after we reset our Graphtec 7000, I can only cut out to about 70" or so. Any ideas on how to remedy this?
signage
try this
SETTING OPERATION
1 Press the MENU key.
2 Press the NEXT key until the following menu appears.
3 Press the F2 key (AREA PARAMETERS). The following menu appears.
Note: ORIGIN is only displayed when the COMMAND setting is HP-GL.
4 Press the F4 key (PAGE LENGTH). The following menu appears.
INTERFACE>
AREA PARAMETERS>
FUNCTION 1>
FUNCTION 2>
ORIGIN>
AREA>
EXPAND>
PAGE LENGTH>
PAGE LENGTH
L = 02000 mm
Use the ( ) POSITION keys to move the cursor to the digit you wish to
change. Next, use the (▲▼) POSITION keys to increase or decrease the
value.
• This setting is retained in the plotter’s internal memory even when the power is
turned off.
• The PAGE LENGTH can be set in the range from 0 to 5000 mm.
6 Press the ENTER key to register your setting.
7 Press the MENU key to return the plotter to Ready
