GRAPHTEC CE-5000-60 / Flexi Sign 8.1 Issue
Discussion in 'Graphtec' started by HVSS, Sep 12, 2011.
  1. HVSS
    HVSS New Member
    22
    Hey guys,
    I just purchased and installed a Graphtec CE5000-60 cutter and I am trying to cut from Flexi 8.1. What is happening is the cutting mechanism which should start cutting from the right side is moving all the way to the left of the vinyl while running out the roll maybe 5 feet or so before it begins cutting. I have no idea why it would be doing this. When I perform a test cut from the cutter it works fine. Any help would be greatly appreciated.
    Thanks.
  2. signage
    signage Major Contributor
    9,517
    75
    48
    Oct 5, 2005
    Penn
    Do a search someone had a similar problem recently!
  3. CS-SignSupply
    CS-SignSupply Very Active Member
    You need to set the Origin or Start point in the Cutter's menu system to LL (Lower Left)
    PAUSE>NEXT PAGE to COMMAND>HP-GL>ENTER>ORIGIN PT = LL
  4. HVSS
    HVSS New Member
    22
    Yep LL it was, you people are always so helpful, thanks!
