graphtec ce5000 missing cuts
mario
hi to all.
i had the graphtec ce5000 for a few months now, and the small problem i have with it is that in each vinyl cut i do for each colour it always leave a bit anywhere uncut, around 10mm long; this is mostly in inside countours. I use the coreldraw x4 and the plugin to cut.
Anyone exeperienced this problem? I'm not sure if i was clear enough.
thanks
JeremySI
hi to all.
thanks
such a coincidence that you posted this and i just posted something very similar.
i have a ce5000-120. is it the bottom of your image that doesnt get cut, as if you deleted the bottom of the image? mine seems to be around a couple inches long and after it does that if i send the image to cut again then it cuts the whole thing
mario
hi Jeremy - well, the missing part could be anywhere really, but i noticed that i can avoid this missing cut from the main cutting by sending a small circle of around 1inc in diameter with an inner circle both combined. The printer then will do the missing cut in this inner circle that i will send to be cut with the other large cuts. Problem solved sort off, but i have to do this all the time.
