ReynaWraps
So I need help. I’ve done research and tried to fix this. But I can not seem to figure this out.
Emailed Graphtec support, no reply yet to my inquiry.
I have a Graphtec FC8000-160. Having issues with the contour feature cutting accurately as it cuts multiple stickers. First few cuts great then the cuts tend to move up (y axis).
What I have tried.
-adjusting the rollers and the tension. (M,m,m,m) cutting on 54 in vinyl. S,m,m,S.
-check sensor off set. (Spot on)
- tried using segments vs 4 points with no segment marks.
- Arms is on.
- Mark is set to detect 4 points.
- mark type 1 and 2 with no help in results.
-steps in the flexi software are set the same as the Graphtec.
- check position 1 in the conditions that are set.
I have attached a video link to show the last cut I’ve attempted.
thank you for your time.
What I have tried.
- Arms is on.
