Graphtec Cut & Creases
Discussion in 'New Member Introductions' started by arcobaleno, Mar 22, 2006.
  1. arcobaleno
    arcobaleno New Member
    4
    Good evening, or good morning for some.
    Has anyone got a graphtec FC4210-60 and managed to Crease and Cut at the same tiime using signgo? I am also experiencing a problem that when I import a dxf file although I indicate the creasing lines and cutting lines in detail the plotter only cuts and does not crease. If I import the same dxf file in Craft Robo it does the job nicely although because it has only one pen it perforates instead of crease. In craft Robo you can see the coloured creasing lines and the cutting lines, but in the signgo software all lines are the same. Do anyone have a way around this problem. Thanks
  2. The Big Squeegee
    The Big Squeegee Major Contributor
    4,954
    107
    63
    Oct 10, 2005
    Lawton, OK, USA
    Welcome
    :Welcome: TO :signs101:
    Don't know the answers but I'd like to welcome you anyway.
    So :Welcome: from Arkansas
