trakers
Up until a couple weeks ago our Graphtec CE5000-60 was flawless. Then out of no where it started doing the following.
On the first cut of the day, on the first character of text, it will move the head over to the location, start going through the X-Y motions of cutting then drop the knife.
So, for instance, if you are cutting an O the outside cut will have about a 3/8' section that is uncut. It looks like the head is moving in the correct fashion, just that the knife doesn't drop for that first 3/8" of an inch.
Damnedest thing I've ever seen.
I need to narrow it down to the cutter or the software first I guess. Just thought someone might say "Well here's you problem".
Also on the Graphtec, I need to change the cut strip because it has a furrow worn in it. People have mentioned flipping the existing strip. Ours in indeed not centered so I think that would work, just need some guidance on removing the old one. It looks to me like it is just stuck down and I should be able to pry up one end and pull it up.
