hiway
Hello,
I have a particular problem with an FC4100-130 cutter. When cutting the cutting paths are inconsistent and dont match from the start of the cut to the end of the cut leaving the path incomplete. In addition, when cutting text, escpecially letter "O" and "D" it will cut the center and by the time the cutting head returns to finish the outer portion the cut is off-center. I have a suspition that is has something to do with the grit rollers or the gear system/belt of the cutting head. The machine I belive is 10 years old and runs practically non-stop from open to close. Has anyone had a similar problem? What was your solution? I am not sure what all has been done to the machine before I got here but I have a suspition, after talking to some of the "Fix-it" guys here that there may have been some frankenstiening done to it to keep it running. Any input would be appreciated.
Thank you.
Thank you.
