Graphtec Driver Install has stopped Windows 7
Discussion in 'Graphtec' started by mikster, Jul 26, 2020.
  1. mikster
    mikster New Member
    1
    Jul 20, 2020
    Toronto
    Trying to install the Graphtec driver on my Lenovo T510 windows 7 laptop and after launching the setup it eventually fails when copying file "Installation Has Stopped." Anyone ever have this problem? Read its a OS problem maybe I can somehow turn security checks off and it might work?
  2. Bert Wondervan
    Bert Wondervan Member
    247
    12
    18
    Nov 8, 2018
    Germany
    Maybe the driver is for older windows and not compatible with Windows 7?
    What is the model of your Graphtec?
    What is your print and cut software?
    • Hilarious! Hilarious! x 1
  3. netsol
    netsol Active Member
    754
    104
    43
    Apr 26, 2016
    englishtown, nj
    ._ maybe your user doesn't have administrative rights? not enough privledges to finish.
    the install?
    go to control panel>accounts\your user. does it say administrator?
    go to file explorer
    clear all the files in c:\temp
    c:\windows\temp
    c:\<your user>\temp
    c:\<your user>\app data\local\temp
    go to control panel\internet and network\clear browsing data\at the next screen make sure EVERYTHING EXCEPT THE FIRST CHECKMARK is checked. delete
    go back to your installation file (setup? or whatever you clicked last time)
    right click and choose "run as administrator". confirm
    see if it completes when you rerun.
    it may not have had rights to install windows components or runtimes required to finish
    • Informative Informative x 1
  4. RustyNZ
    RustyNZ Member
    57
    6
    8
    Feb 22, 2017
    New Zealand
    You could also try run in compatibility mode, right click the installer->Properties, click the Compatibility tab and Run in Compatibility for..... try a few different Windows versions in there, XP SP3 or 7 sometimes work.
