Graphtec FC 7000 spooler error
Discussion in 'Graphtec' started by Angela, Jun 22, 2012.
  1. Angela
    Angela Member
    224
    Oct 7, 2010
    Temecula, CA
    I keep getting a print spooler error when ripping from Wasatch 6.3. Re installed the software, check connection...ie. the basic stuff. I use windows xp....any suggestions? Thanks
  2. StarSign
    StarSign Active Member
    649
    75
    28
    Sep 20, 2011
    Southern Utah
    have you reset the plotter?
  3. Angela
    Angela Member
    224
    Oct 7, 2010
    Temecula, CA
    Graphtec
    Yes, I've reset it
  4. mbfgraphix
    mbfgraphix New Member
    1
    did you ever solve this issue?
    Am having the same issue with wasatch and graphtec combo of I try and cut more than say 20 small stickers.
  5. nopalito24
    nopalito24 Member
    71
    Feb 4, 2010
    So Cal
    for this I strongly suggest you contact Wasatch, because you are getting a spooler error. On the Graphtec you really don't have to set anything up except for your Command option to HPGL.
