nopalito24
I say your other video, and noticed that your left roller is way inside.. It will never work, the roller needs to be on the outside like the righ roller.
So do you do a manual scan on all 4 marks? Please explain more how you do this. thnx![]()
Well, from watching your video, I think you might have the same settings as I do already. If you don't, I went to "Auto Reg. Mark" in the menu, then in "Auto Scan", I set it to "OFF". It was turned on by default on my machine with caused it to do a goffy search all over the media trying to find the first registration mark.
One more thought... Is your media laminated? I found that the eye had problems reading laminated things. Personal experience... however, I have not tried how to reads a matte laminated graphic yet.
First, to turn the Auto Scan featur ON or Off:
Menu, Next until you see BackRoundSettings, select BG, Next until you see Mark Auto Scan, if you turn it off- you'll have to place the tip of the knife inside the first mark when prompted by the software.
Second, your able to have control of there the marks are placed by cutting master: make a rectangle around the image- this rectangle will be your reference or guide, now if you made a rectangle you will now see a "Use Rectangle"option highlighted in the Registration mark box of cutting master, check the box and then hit ok- your marks will appear right where the corners of your regtangle are.
- you might want to visit the Graphtec website for tutorial videos or go to youtube and type in Graphte FC7000 for more tutorials.
To be Frank I think that base upon you questions and the videos that you posted I think the problem is also your procedure-if you never done print a cut w/ a graphtec you must know the steps and sometimes it can get confusing if someone tells you how to do it. but believe me once you know you'll find out how easy it is. but I do think your on the right track.
. The first time I ever even seen a plotter was 2 months ago. Just got the 7000 last week. The machine is really cool. Like mentioned prior I come from a web based graphic background. I have also had to learn how to print as well. For this Graphtec I just wanna thank you all for the support. I cannot find anyone local and this is a sweet resource.
