Graphtec FC8000 Continue Job Question
jasonx
Hey guys,
Just got my machine. Sometimes when doing a job the LCD panel will come up with "Continue Job or Cancel Job" as two options. If I hit continue it keeps going.
What causes this? Is my PC too slow at sending the data to the plotter?
Bigdawg
Just Me
I get that on my FC7000 when it doesn't think there's enough material to finish the job, I just hit continue.
Compilla
Hey guys,
Could be a firmware issue.
Make sure you got the latest firmware installed.
rdm01
If your vinyl hops off of the media feed sensor for a flash it will think that the
media is running out. Happens to me sometimes. Just make sure there is
enough to finish the job and hit continue.
jasonx
Thanks for the replies. Hitting continue job worked fine. But say you were doing a longer run it could be a pain.
I was cutting floor graphics to maybe it was lifting off the sensor.
Joop
A little trick about that media sensor... if you think it may hop off and raise off the sensor, put a piece of masking tape over the sensor, the vinyl will run right over the top of it. I kept the tape on the rear sensor 90% of the time, just took it off if I fed in a sheet of vinyl.
Case
If you pre feed your media the distance of the job before cutting the job, you won't have this problem.. Also you could enable auto pre-feed to prevent it from jumping off of the sensor...
Case
