Graphtec FC8000 Flexi Direction of Cut...
bendeane
This is a question I've searched for (maybe not hard enough) and have come up empty. I'm cutting out 1" x 48" strips (cutting through) and I need the cutter to start cutting at the bottom of the strip first. When it cuts starting with the top of the strip, and then backs up that material to cut the bottom of the strip, the grit rollers lose the media and it start to cut off.
I guess what I'm asking is if there is a way to tell flexi where to start cutting the object it is cutting out and what direction to go.
Thanks,
Ben
Using flexi 8.6 BTW.
