Graphtec help
Fuzzbuster
Ok guys
Graphtec fc 7000 mk2-160
Using flexi 7.6 for cutting
I read the whole manual ,cant find
How do you set it to a PERMANENT Pen/knife condition that will stay the same
Mine right now is returning to condition 2 with default settings
Or do you have to set the darn thing up every freakin cut
and ...is there a one key option for cross cut or do you have to go thru the menu every time
:help::help::help:
Thanx in advance
Case
you can also set the priority under the background settings from program to manual on the plotter so it will just take the setting from the panel on the plotter and not any software you are using.
there is no quick way to cross cut other than going to menu, next, cross cut....
it's easy enough.....
case
Case
destroys the roland in speed and accuracy and has a 3 year bullet proof warranty...
case
Fuzzbuster
Like I said not as EASY but ok
i`ve owned 4 different makes of cutters
Best by far is my graphtec but the simplest one was a roland
from experience
