graphtec issues.............
Discussion in 'Graphtec' started by PMG, Dec 17, 2009.
  1. PMG
    PMG Very Active Member
    2,453
    on my fc7000-130 i can send a perf cut from the cutter controller perfect....when i want to send a normal cut from the controller, i pick my preset (Contour )and send the cut and it wants to pounce cut and not do a normal cut......im at my wits end on this issue i have reinstalled the firmware and the cutter controller and same issue...... i also checked in flexi to see if the stroke was a punce cut bit its set to a solid cut line,:frustrated: i even cleared the plotter many times as well.
  2. Neil
    Neil Member
    337
    11
    18
    Aug 25, 2005
    Adelaide, South Australia
    I seem to remember one of the firmware upgrades changed the default line type to a pounce type.
    Look in Function1/pref line type. Line type no. should = off.
