Graphtec not picking up registration marks?
Fuzzbuster
Graphtec FC-7000 MK2 not picking up left registration marks
Does anyone know what the print limit from left edge of media is for registration marks?
Is there one registration mark setting/shape better than the other?
and is there a way to move print limit in flexisign 8.6 to make sure plotter will pick up the marks on left side
I`m obviously printing to wide but only with multiple decals ...
Thanks in advance
bob
Thanks in advance
Type 2 marks take less room than type 1. Other than that, shrug.
You need at least a couple of inches down each side.
If you want to increase the left margin on your print just tell Flexi that your media is a couple of inches narrower than it really is.
Fuzzbuster
I`ll try that
I was just trying to get as much as i could with a multiple panel print & cut
Give you some feedback this afternoon
omgsideburns
On 54 in material i try not to print my reg marks wider than 50. you need a good inch or so between the pinch roller and the mark, and you have to account for some skew on longer jobs.
Fuzzbuster
Rite
I think thats whats hapening...
these are full 8 ft panels so.. there tracking a fair distance
Also having the same exact problem when printing ..multiples of smaller decals
Do you know of a way to set permanent margins(cut/print margins not media width) in flexi to avoid such cut problems??
gamerxr72
On our Graphtec FC7000-160 I routinely cut things that have Type 1 registration marks with 0.5 inches of space to the edge of the material which is generally 54".
I am sure I could do it with less than that.
If you want to squeek out an extra inch, set your "expand" under area parameters to something more than 0.
The cutter only reads the space between the rollers, and the expand option tells the machine that the material is actually X wider on both sides, X being what to set expand too. I use 0.20. Ive seen it read reg marks that are slightly under the rollers using this method.
