Need Help Graphtec [Plotter help
glen728
Hi, it's been a long while since I visited this site.. Just thought someone here might give me some insight to a problem I am having with my Graphec CE 2000 - 60 plotter. While Cutting a 10 ft. pc and at about the 7-8ft. line the plotter prompt light comes on and stops cutting...and advances the vinyl...i know my machine is old but been running very well...
thanks for any info anyone might share for me....
glen728
just purchased The Create Space software. When I send design from matte to cutter the size is not the same. What should be a yards sign size 22 inches is 6 or 7" wide...Any suggestions to get them together??
Attila Nagy
1. For serial connected cutter the handShake needs to setup correctly (HardWire) to avoid memory overflow. It could cause unfinished jobs.
2. There is a STEP SIZE setting in the cutter. You need to set the same in your cutting software.
0.025 mm/step = 1016 steps/inch
PM me if need help with any of these setup.
