Graphtec Power Interruption
kevinmac
Anyone know if the CE-5000 has a setting to return to after the power goes out. I was in the middle of a job/plotting and lost all power. Wondering if there is a setting on the plotter that might returned to the spooled job at the point of power loss.
Thanks-
Kevin
SignWriteHere
tomence
I can't be of any help on this eventhou i use ce5000 daily. Never had a power out while cutting so to check if there was a setting to just continue cutting where it stopped. I will try do look at it tomorrow to see if there is anything.
Techman
power off means every thing in cache is gone.
The spooler file is usually on the computer..
It may have saved the file but not likely. Most will delete the file when it has sent it all to the machine cache.
