Grommet machines
Discussion in 'Miscellaneous Hardware' started by ChicagoGraphics, May 7, 2007.
  1. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,811
    59
    48
    Feb 27, 2007
    World
    Anybody know whats the best grommet machine there is on the market today.
    (manual type)
  2. Hand operated, check Ebay.
  3. ChicagoGraphics
    4,811
    59
    48
    Feb 27, 2007
    World
    I would never buy anything off of ebay
  4. doublesky
    doublesky Member
    455
    Apr 14, 2007
    Fountain Valley
    I use a stimpson 405 grommet machine. Should have at fellers or signmart for around $200
  5. ChicagoGraphics
    4,811
    59
    48
    Feb 27, 2007
    World
    doublesky, does that machine have the adj. tension on the top?
  6. GregT
    GregT Very Active Member
    Stimpson, but this was just discussed recently.
  7. bob
    bob Major Contributor
    5,273
    306
    83
    Nov 4, 2005
    earth
    There is no best, there is no worst, they're all pretty much the same. This will no doubt elicit howls of outrage from various grommet chauvinsits proclaiming that their Stimpson can kick your Fastsnap's ***. A #2 grommet is a #2 grommet and regardless of posturing, setting a grommet isn't rocket science, it's a simple and mindless application of brute force.
    Look at a grommet set into, say, a banner. Can you, or anyone else short of a forensics lab, tell if it was set with this or that brand of machine? QED.
    Get the one that's on sale today. You might want to be sure that the throat has sufficient clearance to set the occasional long neck grommet. Some of the offshore models do not. Other than that, get the one with the best deal.
  8. Pro Image
    Pro Image Major Contributor
    4,550
    Nov 28, 2005
    I have a Fastsnap............I really like it, never had any problems setting a grommet.............
  9. Chad.
    Chad. Active Member
    659
    1
    Yes, i have the stimpson and my guys love it ... i don't get to use it much, but i guess that comes with being the boss.
  10. myronb
    myronb Active Member
    763
    We use a Fasnap. No problems here.
  11. Checkers
    Checkers Very Active Member
    2,698
    3
    Both Fasnap and Stimpson make good machines. I haven't tried the Hiker though. They're all available through Fellers.
    It's a matter of preference on what one to choose. I prefer the Fasnap because it sits lower on the bench and it's a little easer for vertically challenged people to use. I would mount either to a piece of scrap 3/4" mdo so it can be portable and have a good solid base.
    Checkers
  12. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Stimpson !
  13. threeputt
    threeputt Very Active Member
    3,389
    1
    38
    Mar 10, 2006
    washington state
    The Hiker can do 0-60 in 4.3 seconds but the FastSnap's got it beat in cornering.... Seriously, there aren't a lot of features to compare and go back and forth on. It's not choosing between Lexus and Mercedes. Ours is a Hiker, works fine. Bob is correct.
  14. Signsforwhile
    Signsforwhile Very Active Member
    1,401
    Feb 17, 2006
    New York
    I use a stimpson. Check fellers they have three kinds. Stimpson i think was around $200 with a die of choice and was about mid weight range. That was an issue since i dont have a fixed position for it.
  15. visionsigns
    visionsigns Member
    66
    I have a Hiker and love it. If you ever have an issue, call Hiker directly - they are the best people in the world to deal with.
    I can punch through 6mm pvc like it's nothing.
    I went with Hiker because the die is adjustable to the thickness of the material rather than adjusting the tension of the handle or whatever. Also the Hiker grommets are the cheapest through Fellers
