GS15 plus issues. bad connectors?
Discussion in 'Gerber' started by alistair, Oct 29, 2020.
  1. alistair
    alistair Member
    71
    3
    8
    Jul 22, 2015
    uk
    I have a GS15 plus that I’m trying to fix and when I cut the test file I’m getting bad results, seems to be affected by the connectors that go from the motors to the board, if I wiggle the connectors I sometimes get better results. How can I get a more consistent connection? Replace the connectors? If so where would I find some?
  2. balstestrat
    balstestrat Member
    360
    43
    28
    Aug 25, 2020
    Europe
    Picture of those?
  3. Attila Nagy
    Attila Nagy Member
    47
    8
    8
    Sep 24, 2018
    London
    GS15 :). Can I fix it for you. The main time you can use my envision.
  4. alistair
    alistair Member
    71
    3
    8
    Jul 22, 2015
    uk
    I have an envision, this is a back up machine
  5. alistair
    alistair Member
    71
    3
    8
    Jul 22, 2015
    uk
  6. balstestrat
    balstestrat Member
    360
    43
    28
    Aug 25, 2020
    Europe
    Well you can remove the pins from the connector and check if there is something wrong. Then you can take out the PCB and re-solder the connector/pins.
  7. Attila Nagy
    Attila Nagy Member
    47
    8
    8
    Sep 24, 2018
    London
    That connector hardly fails. Check soldering quality especially for the bigger parts or parts around heat sink. While you pressing the connector you possible bending the motherboard too. Once I had to replace the white ribbon cable for this machine.
    • Agree Agree x 1
  8. netsol
    netsol Active Member
    826
    115
    43
    Apr 26, 2016
    englishtown, nj
    attila
    you beat me to this one
    if th board is pulled out and flippe over, there will be a couple "ringed" connectors
    just resolder with a fullsize weller or other soldring gun
