GS6000 - Logo Length Not Matching
Discussion in 'Epson' started by Jgentry, Jul 1, 2011.
  1. Jgentry
    Jgentry Member
    64
    Hi guys
    I printed a 97" circle (logo) on my GS6000 on 54" IJ180. Colorburst printed the left half (seam edge to the right) then the right half (seam edge to the left) of the logo with a 1/2" overlap. One side turned out to be 1/4 inch longer (top to bottom along the seam) than the other. Needless to say installation was a bear trying to stretch the short side to make things match up.
    I was using the take up reel. When enough material printed I taped the center to the reel and things seemed to go fine from there.
    What can cause this?
  2. Christian @ 2CT Media
    Christian @ 2CT Media Major Contributor
    4,597
    711
    113
    Jun 15, 2009
    Mesa, Arizona
    RIP error.... Most likely. Did you print from a scale or full size file?
    Also did the RIP provide the split or you?
  3. signmeup
    signmeup Major Contributor
    7,468
    13
    38
    May 5, 2005
    Canada
    Dirty pinch rollers?
  4. Jgentry
    Jgentry Member
    64
    The graphic was from illustrator on a full size artboard. It was split automatically in Colorburst. The printer is new and this is the first large seamed print done on it.
  5. sfr table hockey
    sfr table hockey Very Active Member
    1,212
    Jan 24, 2009
    Alberta
    Any chance that the longer side was the second one printed (right half)?
    If so it may have something to do with the takeup reel if your takeup reel has a bit of tension.
  6. astro8
    astro8 Active Member
    778
    17
    18
    May 23, 2009
    Sydney, Australia
    If you need critical matchup as in paneled pieces always use a leader to reach the take up before printing and make sure the media lever is pushed all the way down. I had some problems with panels lining up at first but since using a leader no problems at all.
  7. Jgentry
    Jgentry Member
    64
    That really adds alot of waste when using expensive media like ij180. I like the suggestion to fully engage the lever. That makes sense. Just not sure why letting it print down to the take up would be a problem, but if you say it will help of course I will try.
    Do you think it could be the roll feed adjustment left/right being off?
  8. astro8
    778
    17
    18
    May 23, 2009
    Sydney, Australia
    No you don't waste your expensive vinyl, you use a leader from scrap or have one on a core that you take up to the vinyl. Letting it print down to the take up means it has no tension from the front so your print length is far more likely to be different.
    It's not just the epson, I've used this method on every printer I've had.
    90% of stuff you don't worry about, it's just when you have panels that you need to be precise.
    You should get a level, a square and tape measure and square everything up. Measure from the platen to the take up and adjust until everything is set up square and true.
    Do you have the updated version of the media holder? If not get onto Epson.
  9. insignia
    insignia Very Active Member
    For what it's worth, we have this issue quite often with our GS6000 and so far haven't found a reason for it, or a fix. I'm leaning toward the printer, not the RIP. We run Onyx. I can print a multi-tiled job on the Epson and have panels be off from one to another by as much as an inch, the same job from Onyx (same RIP computer) to our Mimaki with no problems. It has happened with the takeup reel and without which leads me to believe it's either electronic or the feed compensation likes to do whatever the hell it wants (I'm leaning towards the latter).
    I've said it before, I'll say it again, the GS6000 is NOT all it's cracked up to be. I bought one against my better judgement and have been kicking myself ever since.
  10. Bly
    Bly Very Active Member
    3,045
    365
    83
    Mar 9, 2004
    Sydney
    This won't help the OP but Onyx has a scale adjustment in the rip.
    When creating a profile you print a set length, measure it then enter the actual length and it will compensate to error.
    Before we started doing this long prints (3 metres plus) were sometimes 10 or 15 mm out.
  11. boxerbay
    boxerbay Active Member
    938
    71
    28
    Nov 25, 2010
    Darkside of the Moon
    fully engage the lever all the way down.
