GX-24 wont load material correctly
jfk252
My gx-24 wont load properly, with vinyl in the machine and it gives the prompt for 'roll', piece, or edge' when pressing 'enter' to any of these options, it will give a 'W' of 2mm or say 'bad position'. Disconnected power and restarted machine, but no change. Any one know why this is happening?
stoliker
We have had ours for about four years and a month ago it started doing the same thing. Still haven't figured it out. For 24" vinyl it is fine but anything smaller is an issue.
jfk252
gx-24
Pinch rollers are underneath the marked white areas, it will give a 'w' of 2mm, then maybe 4mm, then 7mm them maybe 'bad position'
OldPaint
older machine???? well used??? there is a cable strip on the top of the machine. remove the top cover, this cable moves with the cutting head......check it for any abrasions.......new one is under $50.
jfk252
GX notw
Thanks for replies, after 5 hours tit just started working correctly again!, whether it will stay working is another question.
