Gx-24
muledalton
Does my GX-24 cutter have a vacuum inside of it that help suck the vinyl flat against the roller? It sure sounds like it when I remove the vinyl because the noise of the machine really changes.
muledalton
In that case I think my vacuum is causing a lot of static build up that is not allowing the vinyl to feed smoothly without rippling. The only problem is that I only have a 2 pronge power cord that came with the machine. Would figuring out a way to ground it help?
