Gx-300 Vs Cx-300
Discussion in 'Roland' started by mrvixx, Apr 4, 2007.
  1. mrvixx
    mrvixx Member
    30
    What are the differences??
  2. visionsigns
    visionsigns Member
    66
    The main difference that I'm aware of is the GX-300 has an Optical Eye Sensor for automatically detecting crop marks on printed vinyl.
    The CX-300 (1 generation older) has a crop mark detection tool that you use to manually align the crop marks.
    I had a CX-300 and it worked flawlessly. Are you pairing this with a printer or a stand-alone cutter? If it's just a cutter, save the money and go with a used CX-300.
  3. FatCat
    FatCat Very Active Member
    1,931
    161
    63
    Feb 12, 2007
    Columbus, Ohio
    Here are specs for the GX-300
    http://www.signwarehouse.com/cutters/Roland/roland_c1pro_content.htm#specs
    ...and here are specs fro the CX-300
    http://www.studica.com/products/product_detail.cfm?productid=10041
    Appears to me other than some minor differences they are essentially the same machine. (I have the CX-300) Aside from the sensor update that Visionsigns mentioned, the newer GX model will come with newer drivers/software to use with more current computers and design software like Adobe CS & CS3. Roland makes good stuff.
  4. High Octane
    High Octane Active Member
    923
    13
    18
    Mar 27, 2005
    Fenton, Michigan
    My CX Rocks!...never one day of porblems in like 5 years
  5. mrvixx
    mrvixx Member
    30
    Thanks. I will only be using it as a cutter. I will be going with the CX then.
