Signs of All Kinds LLC
Hi Evan,I scanned through the tech pdf on your site, how many coats do you usually do (I know its says 2 recommended, but do you do more than 2 sometimes?) for carved or blasted areas with texture (wood grain) how are you applying? If you spray, what is the equipment set up?
Seams like a long time between coats, what does your drying setup look like (leave in a booth or ?)
Lastly, what are you usually topcoating with? Is it compatible with the types of paints (mathews, one shot....)
I always let anything dry overnight as a general rule, especially if we are priming for top coating and then masking before carving. You can get away with less dry time. I've painted carved letters in a sign foam sign in the morning and topcoated them with oneshot at the end of the day before no problems. 2 coats are usually sufficient, brush and roll. You could spray this but like any heavy latex paint, you need a wider nozzle in your spray gun, or a true turbine set up. A 2.2 nozzle in a HVLP gun would work. We stick to brushing and rolling mostly.
I've used Oneshot/Chromatic, Ronan sign paints, and have sprayed 2 part polyurethane paints like Akzo GGP for topcoats.
I've found that with sign foam, blowing off as much of the dust with compressed air first is the best for adhesion. Our drying set up is basically open air in the shop.
We've used this on cedar too, as well as a primer for painting the exterior of a couple family houses.
Hope this all helps.
-Geoff
