nolanola
https://manhattansignshop.nyc/
Hello Signs 101,
We are looking to create a routed and painted HDU sign. The desired width is 2".
The route we have gone to create panels in the past is to route two 1" panels and glue them together with threaded studs embedded. We are wondering if there is an easier way to get the same effect or if the panels need reinforcement?
Can 2" HDU be drilled into and glue poured into the holes, and the threaded studs inserted?
Does HDU bow over time and need some kind of reinforcement between the 1" panels?
Any advice is appreciated.
Thank you.
Thank you.
