Heating Issue with VP-540
stillhasdust
Whenever I send something to print it always sits on "now heating" The temp never goes up or down. Does anybody know the cause of this??
stillhasdust
The print temp is set to 40 degrees C and the dryer temp is set to 50 but the dryer temp just stays at 46 degrees and doesn't increase.
Drip Dry
4 deg doesn't seem too much of a difference.
Did you try to raise the value and see if the temp goes up ?
Raise it at the control panel on the printer, but if using versaworks, the printer can be overridden by the software
