Hello guys i really need your help!
Discussion in 'Newbie Forum' started by riciozo, May 18, 2020.
  1. riciozo
    riciozo noob
    4
    May 18, 2020
    MKD
    Hello just am new to the forum, really need your help, after spending alot of time and variations searched on internet and found this great forum!
    Am in bird rings business after doing trade this year i decide to buy a machinelong and start my own production long short story, the machine is plastic injection and my final product contains aluminium core > then sticker (printed on xerox docu) with text or logo then we put in in tho the mold and plastify it on 210-220 C under high pressure ....
    The machine mold has 12 cavities , the problem is that the color and sometimes even the text/logo on the sticker (paper) it gets blurred on the spot from where it injects the plastic into the mold/slot ...
    What i really need is some suggestions for printer/machine or paper that will be able to handle the 210-220 C temperature and high pressure so my bird rings be perfect ....
    here are few pictures as example for what am doing and what happens to my product ...
    the stickers are 8mm height on 30mm width printer on laser adhesive paper mufflon with xerox docu printer
    example photos of my problem :/
    https://ibb.co/DDx5QQC
    https://ibb.co/pwsFrVW
    https://ibb.co/7bp8JpR
    https://ibb.co/QQHtxqJ
    https://ibb.co/CHbbXHH
  2. Andy D
    Andy D Very Active Member
    2,302
    428
    83
    Oct 20, 2014
    Hattiesburg, MS
    When you say "Bird ring" I take it you mean leg bands for birds?
    Have you tried laminating the vinyl before the injection process?
  3. unclebun
    unclebun Very Active Member
    I think the problem is that laser toner melts at 110 degrees C.
    • Agree Agree x 2
  4. riciozo
    riciozo noob
    4
    May 18, 2020
    MKD
    yes leg bands for birds and pigeons - ive tried and it also blurrs even more :/
  5. riciozo
    riciozo noob
    4
    May 18, 2020
    MKD
    probably but do you have a suggestion for solution? :) any other printer that is bulletproof to high temperatures ... ?
  6. Andy D
    2,302
    428
    83
    Oct 20, 2014
    Hattiesburg, MS
  7. riciozo
    riciozo noob
    4
    May 18, 2020
    MKD
  8. JBurton
    JBurton Signtologist
    1,827
    362
    83
    Sep 28, 2017
    Arkansas
    I know this is old but...
    You may look into UV cured inks off a UV printer.
    I could be wrong, but I'd think a thermal print may go all black if exposed to enough heat. Almost all inks are temperature dependent in some fashion, except for UV ink (I think).
  9. Sindex Printing
    Sindex Printing Member
    152
    36
    28
    Nov 17, 2018
    Sparks
    Have you tried going with a tyvex label with a liquid protective coatstock. I have a customer looking for decals to go on burn barrels. Everything I found would last last for the time the customer was asking for. Tyvek label stock was about one of the best for durability. Hope this helps
